The car I'm working on originally had electric tailgate window, but someone put a manual in it. Now I am putting an electric regulator back in and ran into a hangup on mounting. Does the electric assy. mount in the upper set of holes in the tailgate instead of lower like the manual ? If so are the cup washer spacers used only on the bottom 2 holes and no spacers in the top ?
Wagonaire tailgate window motor mounting
Tags: None
The manual says to install the regulator on the the studs using the ORIGINAL shims. That will be tough if you don't have them. Personally, I would start mounting and remounting with a variety of shims until I found the right combination.
Obviously we have the forum so I hope someone gets back to you with an easier solution...
