Just noodling, would a 259ci, V-8 framed Wagonaire be able to tow a tent trailer? Small camper trailer? Safely? Just curious about average towing loads, nothing freaky, and a capable 259 drivetrain.
Wagonaire capability
Tags: None
I keep thinking about putting a hitch on the back of my '65 Wagonaire so I can pull my 4' x 8' utility trailer and another one made from an old M5 pickup bed and a front solid axle, just haven't jumped on one of the universal frame mounts. A Class I hitch is good for 2000 lbs of trailer weight and 200 lb tongue load. You might want a heavier hitch but higher tongue loads won't be fun. The Reese Class II Multi-fit 88001 looks like it might work. But, even with a Class I set-up, you should be good for many of the smaller tent trailers and campers. The old-style hitches of the '60s that tied into the bumper and the rear cross member are too scary for me. I guess I haven't found a hitch that will fit under and around the bumper, but maybe a shop that does custom hitches could solve that.Gary Ash
Dartmouth, Mass.
’41 Commander Land Cruiser
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
I sure think it could tow it just fine, I towed a 1950 Commander behind my 1950 Commander from El Paso to Brooklyn Park, MN, 1500 miles with no problem. In fact I did it twice to bring home my 1952 Land Cruiser when I got out of the Army. I should have brought home more cars from El Paso, due to the rust free bodies, but the 3 Studes was a good start.
I was in charge of the welding shop in the Army, so I made a bumper clamp hitch and towbar for the job. It all worked fine. Half way home I was in the middle of Kansas and went over some dips in the road, so I pulled over to double check everything. What a stroke of luck, because the hitch ball was hanging on by one or two threads. Seems after I installed it by hand I had forgotten to put the wrench on it.Last edited by TWChamp; 01-09-2015, 05:03 PM.
Originally posted by LeoH View PostJust noodling, would a 259ci, V-8 framed Wagonaire be able to tow a tent trailer? Small camper trailer? Safely? Just curious about average towing loads, nothing freaky, and a capable 259 drivetrain.
Yes, I was kind of dumb back then, but I got away with it.Paul Johnson, Wild and Wonderful West Virginia.
There was a gentleman in Knoxville, TN who owned a 63 Wagonaire he used for his well supply and water softener business. When he died, the car had over 500,000 miles on it. It was held togehter with baling twine and chewing gum, but still ran. Tommy would haul a ton of water softener salt in the back of the wagon, sometimes going over the Smokies to Asheville, NC. Pulling a small trailer should be no problem.
Originally posted by garyash View PostThe Reese Class II Multi-fit 88001 looks like it might work.
Originally posted by 53k View PostI did pull the trailer to Hangtown (Placerville) which is high in the mountains, to Santa Cruz over the coastal mountains and to San Luis Obispo (returning from SLO to Atascadero was a long, 10mph, gas pedal to the floor white knuckle experience though. However, at 130,000 miles the original clutch was still OK.
Thank you guys. I'm looking for a light hauling vehicle, and I've been thinking about the big trucks, but maybe, for most of what I plan to do, possibly a wagon, with a sleeved 'box', something like what was offered on the '40s business coupes, to keep the muck to a livable level coupled with the versatility of a small hitched trailer; maybe that's something I should consider pursuing. Making a utility carrier box like that shouldn't be difficult, and with a sliding roof, it would offer the chance to stuff in larger debris.
The big trucks are cool, I do like the idea of low gears for rumbling off road, but then again, if I were to put a small lift in the back of the wagon, and taller springs in the front, in order to give myself some basic ground clearance, it might suit my needs.
