I was looking under a 66 Commander, six cylinder car the other day an noticed the front sway bar did not attach to the frame. I was under the impression that all later cars had sway bar mounts on the frame. Is this a six cylinder/V-8 thing? I supposed I could get off of my lazy butt and get in the parts catalog and investigate, but I figured someone woud know.
Another sway bar question
Frame / Springs: Another sway bar question
Hope Mills, NC
1963 Lark "Ugly Betty"
1958 Commander "Christine"
1964 Wagonaire "Louise"
1955 Commander Sedan
1964 Champ
1960 LarkTags: None
That is EXACTLY what it is! Studebaker knew they did not have enough front weight or Power in those Cars to need the kind of handling and anti-dive that V8's need.
The early Sixes had NO Stabilizer Bar, then later when one was added to the 6's they did not use the frame mounted V8 '58-'62 or '63-'66 Type, but the old '55 to '57 V8 "A" Arm only mounted one.StudeRich
Re: post #5. I assume that would even apply to my '57 Clipper Wagon. I've always installed much larger sway bars and high performance shocks (Koni/Bilstein) on all my cars as they simply work together to make a much better handling car.
Bill
Originally posted by Buzzard View PostRe: post #5. I assume that would even apply to my '57 Clipper Wagon. I've always installed much larger sway bars and high performance shocks (Koni/Bilstein) on all my cars as they simply work together to make a much better handling car.
Billsals54
