Does my 55 2 door president state coupe have ball joints ? I have to know as this is interesting to know what takes its place?
I heard recently that some fifties cars didn't have ball joints?
Studebakers like many older Cars and fairly Late Model Cadillac's and Trucks up to current, used KING PINS.
These connect the Upper and Lower "A" Arms, so you only need ONE per side not 2 like a Ball Joint.
Ball Joints are NOT to be confused with "Tie Rod Ends" on the ends of the Steering Tie Rods that all Cars have.
Coincidentally, you have a '55 Stude., I believe that is the first year Chevrolet switched to these cheaper replacements with very short life, called Ball Joints.StudeRich
14x7 -
Simple answer, no, Studebakers do not have ball joints, at least not from the factory.
The spindle is connected to the control arms with pins that go thru the control arms and a section of the spindle, both top and bottom. While this system has it's problems, overall, it's actually stronger thAn modern ball joints in many instances.
But as noted, its adjustability (overall suspension) is VERY limited.
The spindle itself is made up of parts that are not, unlike a beam front axle of earlier cars. In this case, no stronger or weaker than a modern cars spindle. Just made up from "many" parts, rather than one big casting as in a more modern car.
Hope that helps.
"Coincidentally, you have a '55 Stude., I believe that is the first year Chevrolet switched to these cheaper replacements with very short life, called Ball Joints."
I am glad you alerted me to this. I will have to keep an eye on the front ball joints in my Mitsubishi Montero when the mileage gets up there - right now it only has 335,000 miles. So far even the original rubber boots are in good shape, including the ones on the axle shafts.
Trying to build a 48 Studebaker for the 21st century.
See more of my projects at stilettoman.info
Originally posted by 48skyliner View Post"Coincidentally, you have a '55 Stude., I believe that is the first year Chevrolet switched to these cheaper replacements with very short life, called Ball Joints."
Oglesby,Il.
Originally posted by studegary View PostAvantis did not go to ball joints until the 1987 model year.Don Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
