What colors were they? I have seen one that may have been original that was brown. Mine was originally a 6 Cyl 57 Transtar. Wasn't there a Stainless cover that came on certain model years or was it an option?
Truck Heater Core Box Color
Cool/Heat: Truck Heater Core Box Color
My 1st car. "A TRANSTAR"
Starliner
Somewhere between Culture and Agriculture
in the Geographic center of TennesseeTags: None
I cannot speak to the earlier R series C-Cabs where I have seen the aluminum heater boxes (hence the "stainless" color). All of the E-series C-Cabs I can recall had the heater box either painted the inner fender color or black. I am sure that others can chime in with more specific details.Mark Hayden
'66 Commander
There were four different C-cab heater boxes, the first three of which are well described in the 49-56 parts book. They came from an outside supplier and I believe types A, B, and C were all originally painted a tan/brown color. Type A had an aluminum front cover with a lazy S emblem cast into it that was originally painted, but can be polished up nicely. However,it will not fit on the later boxes. If you want one of those, you would have to buy a complete unit, as none of the parts will interchange. The last type began use midway through the 1959 4E series, and was painted green. A 1957 3E-series truck was originally equipped with a type C heater, and was painted the tan/brown. Any good paint store (not necessarily automotive paint) can match it quite well in high-gloss oil-based enamel if you can find a clean sample of the old paint to bring in as a sample. I was able to do that and it looks great.Skip Lackie
Thanks Skip!
Originally posted by Skip Lackie View PostThere were four different C-cab heater boxes, the first three of which are well described in the 49-56 parts book. They came from an outside supplier and I believe types A, B, and C were all originally painted a tan/brown color. Type A had an aluminum front cover with a lazy S emblem cast into it that was originally painted, but can be polished up nicely. However,it will not fit on the later boxes. If you want one of those, you would have to buy a complete unit, as none of the parts will interchange. The last type began use midway through the 1959 4E series, and was painted green. A 1957 3E-series truck was originally equipped with a type C heater, and was painted the tan/brown. Any good paint store (not necessarily automotive paint) can match it quite well in high-gloss oil-based enamel if you can find a clean sample of the old paint to bring in as a sample. I was able to do that and it looks great.Mark Hayden
'66 Commander
