It's 1-5/8" type used on '64 Hawks from heater blower to defrost vents. Nothing available in that size locally...any ideas?
Source Needed: Air duct coil tubing.....
The 1 3/4 Inch X 6 Inch defroster Ducts #800514 are for '49-'58 Models, the 2 Inch X 6 Inch #800515 is for '59-'66. You must have mis-measured.
They would go from the Fiberglass Heat distribution Tube/Box to the Windshield Outlets.StudeRich
Studebaker had a very unique "Clamping" method on '59-'66's; at the Distribution Duct end, a 1 3/4 Inch piece of 5/16" or 3/8" Fuel Hose stuck between the 2 Duct Hoses.StudeRich
The 2" hose will work and can be fairly well sealed with a couple of hose clamps. I've never seen a judge look under the dash to see if the heater hose diameter was correct.Brad Johnson,
'56 Sky Hawk in process
Originally posted by StudeRich View PostThe 1 3/4 Inch X 6 Inch defroster Ducts #800514 are for '49-'58 Models, the 2 Inch X 6 Inch #800515 is for '59-'66. You must have mis-measured.
Originally posted by Lou Van Anne View PostThanks everyone. I rechecked and stand corrected, they are 1.75. The search continues....
Per Post #3.StudeRich
Originally posted by acolds View PostI have a novel idea for attaching hoses, product called duct tape possibly could be used for its name sake rather than every other use thought of by mankind
I bought new hose from SI and attached it properly.sigpic
55 President Deluxe
64 Commander
66 Cruiser
37 Oldsmobile F37 4 Door
Why would there be a point deduction for using duct tape underneath the dash? There's nothing in the club's judging guide that requires examination of anything underneath the dashboard.Mike O'Handley, Cat Herder Third Class
Kenmore, Washington
hausdok@msn.com
'58 Packard Hawk
'05 Subaru Baja Turbo
'71 Toyota Crown Coupe
'69 Pontiac Firebird
(What is it with me and discontinued/orphan cars?)
