hi looking for a v8 and auto for my 62 studebaker lark-currently running a 170 straight 6 and auto. based in the uk.
Looking for a V8 in the UK (Was: re v8)
Sorry, there are DOZENS or more posts here about what fits and what does not, and the pitfalls you may not be expecting to do a good changeover to V8, but unfortunately all of my "Searches" came up dry, due to usually very poor Titles.
Not to discourage you from doing the change, because the result will be a ten times better car, you just really need a Parts car to get all of the Brakes, Springs, Rear Axle, Converter Housing, Torque Converter, Transmission, Engine Mount Brackets, etc. Parts and all the Linkages, levers, Rods, Driveshaft, etc. for the connection to the 6 Cyl. Car.
Located where you are, that is likely going to involve some serious Shipping from the U.S., Canada or Australia, where Studebakers and their Parts abound.Last edited by StudeRich; 12-26-2014, 01:45 PM.StudeRich
I agree with Rich. I bought a parts car (60 Lark 4 door deluxe) around 9 years ago which has come in handy for my 59 Lark wagon engine swap. With my swap I'm going from a 6 cylinder overdrive to V-8 automatic, plus adding power steering & before it hits the road, disc brakes up front. the first thing I found needed was the frame brackets for the motor mounts. Being it's now an automatic the brake pedal has to be changed, then on to the radiator and wiring, although if I can make a slight modification with the generator (dynamo to Brits) wiring I will.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Hi,
I have a nice late model 289 V8 with full flow oil, automatic with all the connecting linkages generator and carb here in the UK. The engine has a blown head gasket on one bank, but I do have a new full gasket rebuild kit for it.
The motor would need to be pulled down, but you should be able to get away with a new seal kit in it and you would be really motoring. Your diff should be fine, but you may need to update the brakes, depending on how Belgian assembled cars like yours is were set up.
Chances are you will have to use different front springs, so I may be able to help you out there as well.
I have a picture or your car in 1974 at Beauieu if it is ulw 96f when it was just white.
Here in the UK there really isn't anybody who can help you with the big heavy stuff as nobody seems to want to store it for a rainy day.
Give me a call in Warwick on 01926 733 484
Seasons greetings
Greg DiffenGreg Diffen
Editor Studebaker Owners Club UK magazine
Australian Stude guy living in Warwick, United Kingdom
1933 St Regis Brougham Model 56 delivered new in the Netherlands
1937 Dictator sedan Australian Body by TJ Richards RHC
1937 Packard Super 8 Limousine UK delivered RHC
1939 Packard Super 8 Seven Passenger sedan monster UK delivered RHC
1939 Commander Cabriolet by Lagenthal of Switzerland
1963 Lark Daytona Hardtop
1988 Avanti Convertible
In addition to the engine and transmission that Greg has available, we can certainly help you out with any of the RHC specific parts needed to complete the conversion, and lots of advice. All RHC automatic cars used a gear selector cable and various brackets, plus a slightly different throttle bellcrank, etc. Just let us know if you need help.
Chris
STUDEBAKER of AUSTRALIA
