'64 GT Dash with A/C
  • Interior: '64 GT Dash with A/C
    Does anyone know if there was a service bulletin issued when dealers were installing factory A/C in late '63/4 GT's? It seems that the dash needs to be cut near the brake handle so the evaporator will set evenly under the dash. I bought the installation instructions from SDC but there is no mention of cutting the dash. I've looked at several late GT's with factory A/C noting that each dash was cut with a slight curve to enable the evaporator to fit snugly under the dash. I also noticed in the parts book that there is a different part # for the Climatizer/air/heater duct on '64 GT's with A/C. Is it slimmer as to allow the evaporator to tuck closer to the firewall? I know on '64 Lark models you need the narrow duct from a '63 Lark to install the A/C evaporator-otherwise the glove box can't open! Any help is appreciated as I'm trying to finish up the dash to install in the Hawk after the body work is done.
    Rob in PA
