I get the scary feeling that without an engine or the weight of a body on this frame, there's not going to be an easy way to 'open up' the front end without a body part flying across the room. I was using the floor jack under the lower arm, with that chain.
I'd like to put in a new set of springs and press in a set of delrin bushings. Should I just clean it all up as best I can, replace the engine/tranny then do it? Thanks.
Western Washington, USA
