I had already commented, in another thread, about gas tank leaks, that I was going to attempt to diagnose where my tank was leaking. Today, in-spite of spending most of the morning, filling out forms for the Veterans Administration (redundantly chasing down information they have on file...again and again). So far, I have not had any problems with high blood pressure, but...attempting to negotiate this cumbersome bureaucratic maze might do me in.
Anyway, I finally got to this long overdue task. Once I had the seat out, removed the access plate to the gas gauge sending unit, I performed a "soapy water test" on the sending unit. Using a small amount of soapy water brushed over the unit, and blowing in the tank produced some small bubbles. However, I sensed that the amount of gas that spilled out on the ground, the last time I filled the truck, couldn't have come from that area.
I decided to investigate a little further, by removing the filler tube and the rubber connector between the tank filler tube and the piece of tube that holds the gas cap. Well...this is what I discovered.
This is a relatively low mileage never "off-frame" truck. The good news is that the tank looks new inside. The bad news is that I'm gonna have to remove it to repair it. Another thing, I noticed, is how the tube position is not centered in the opening of the truck floor. I wonder if that could have caused stress on the tank tube, vibrating over the years, and causing the soldered joint to fail.
I have always been good at soldering. 'Cept my soldering has always been strictly copper/brass connections. Not steel, and certainly in no gasoline container. Unless some of you folks have experience with a sure fire (OH MY...perhaps I should stay away from that word!)...fail proof adhesive/joint compound...I suppose I'll have to find someone to re-solder this thing.
Anybody else experienced this kind of failure on C-cab trucks? Most of the gas tank problems we discuss seem to involve rust, or accidents.
