I am missing the black bakelite 1/2 of a pill capsule looking thingy{bout 3/4 long, hollow and bout 3/8 inch diameter} that rides atop a spring which is inserted into a stamped brass cylinder that inserts into the steering wheel end of the steering shaft. This assembly helps the horn sound off. I ordered a new horn wire and sorta thought I was getting a complete apparatus but just got a wire. Don't even ask what I did with my thingy. If I told ya I'd have to kill ya. Below are a couple of photos perhaps to make things more understandable. The missing part isn't pictured. Can anybody help me so as to procure another one. Like what is it called? do you have one? Do you have the complete wiring apparatus or who might? thanks jimmijim
Horn wire apparatus needed for 55 President K model with manual steering {can you help?}
Steering: Horn wire apparatus needed for 55 President K model with manual steering {can you help?}
sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** memberTags: None
you need a 196673 cup and a 532201 spring. They used the same cup from the forties on. I think the original cable, 532908, came with these parts but the replacement cable 1539065 which is more generic does not have them.Milt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
Why thank you Milt. I think I have the what you may be referring to cup and I have the spring. I'm in need of the plastic button thing that looks like half of a pill capsule. cheers jimmijimOriginally posted by unclemiltie View Postyou need a 196673 cup and a 532201 spring. They used the same cup from the forties on. I think the original cable, 532908, came with these parts but the replacement cable 1539065 which is more generic does not have them.Last edited by jimmijim8; 12-05-2014, 02:18 PM.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
That sounds like the top insulater/ guide for the horn sounder wire. not sure its available seperately. try making one? i'll keep my nose to the ground, i know a 55 horn expert with a faultless memory, if i can remember his name LOL. Doofus
Originally posted by jimmijim8 View PostI am missing the black bakelite 1/2 of a pill capsule looking thingy{bout 3/4 long, hollow and bout 3/8 inch diameter} that rides atop a spring which is inserted into a stamped brass cylinder that inserts into the steering wheel end of the steering shaft. This assembly helps the horn sound off. I ordered a new horn wire and sorta thought I was getting a complete apparatus but just got a wire. Don't even ask what I did with my thingy. If I told ya I'd have to kill ya. Below are a couple of photos perhaps to make things more understandable. The missing part isn't pictured. Can anybody help me so as to procure another one. Like what is it called? do you have one? Do you have the complete wiring apparatus or who might? thanks jimmijimJerry Forrester
Forrester's Chrome
Douglasville, Georgia
Jerry, will call you Monday. jimmijimOriginally posted by Jerry Forrester View PostI think I have what you need. It'll be Monday before I can check. Call me Monday to remind me.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
