Hey guys, I have a 46 Skyway Champion. 4 door. My stock chassis is unusable. I found a 41 5 window business coupe frame for sale locally for a decent price. Does anyone know if these are even close to being the same? Will I be able to adapt the 41 frame to my 46? Thanks if you can help.
Frame interchange question
I don't. But if no one else chimes in, start with the wheelbase. If that's the same take lots of measurements and lots of pictures. And since you probably only have access to the bottom side of YOUR frame, make sure you work from the BOTTOM of the one for sale. It would be tempting to just look at the visible top side of the one for sale, but you need to view it from the bottom, same as yours.KURTRUK
Originally posted by jrlemke View PostMy '53 Hollander says '41 to '46 Champion frames are all the same. Gives p/n 515234. $60.43! Hollander #1577. You should be good to go. -JimJoe Roberts
Originally posted by JRoberts View PostBut are 4 door and the business coupe frames the same?Diesel loving, autocrossing, Coupe express loving, Grandpa Architect.
