hello all , can anyone tell me what sort of pressure would be going through the power steering hose from the pump to the saginaw steering box for a 1957 hawk , i am getting guy to make me up new hoses and he asked the question , any help would be welcome . thanks from roger
1957 power steering pressure
Do you have your old hoses to copy?
The saginaw PS used on '53-'57 Studes was sourced from GM. You may find some tech specs searching for GM applications. I know I tried to find pressure spec's some years ago and gave up. I was told by a rebuilder tech when I had the Saginaw PS box rebuilt to NOT use a modern pump designed for rack & pinion with it as the pressures would be too high.
Note the pressure line from pump to gear box has a flow restrictor in it. If you have the original hose, it will look like it has a splice about 1/2 way. That is the restrictor. The return hose dose not have significant pressure and just has a hose clamp on the pump reservoir.
I had a local hydraulic hose place make me new hoses. They could not source the 45 deg SAE spec flare nuts that attach to the gear box and cut the tubing from the old hoses and welded it to the new. Watch out for that.
Jeff in ND
Originally posted by studevic View Posthello all , can anyone tell me what sort of pressure would be going through the power steering hose from the pump to the saginaw steering box for a 1957 hawk , i am getting guy to make me up new hoses and he asked the question , any help would be welcome.The saginaw PS used on '53-'57 Studes was sourced from GM. You may find some tech specs searching for GM applications. I know I tried to find pressure spec's some years ago and gave up. I was told by a rebuilder tech when I had the Saginaw PS box rebuilt to NOT use a modern pump designed for rack & pinion with it as the pressures would be too high.
ger
jack vinesPackardV8
To me, High Pressure is HIGH PRESSURE, any hydraulic fluid hose should be able to take Hydraulic Pressure of up to at least 2000 Lbs. so any Tractor type hydraulic hose should be just fine.StudeRich
hi all, thanks for the advice , i do not have the original hoses or pump to go from , also the pump on the car now is a later model type shaped like a can of ham , i have been told that the pressure in this type of pump can be lowered if needed , again thanks from rogerR.A.Jennings
