Anyone here ever work on a Subaru Outback, specifically the CV axles.... My past adventures have taken me through the Volkswagons and Acuras and never has the axle maintenance ever given any problems. However Subaru has managed to make the task great for their owners to get to and remove, but absolutely miserable to re-install.
Recently had to reboot the inner drivers side on this 07 and it was great to NOT have to deal with compressing the coils spring to remove the axle, just unbolt the lower strut, move things out of the way and pull the axle out....
Returning it, however required a special tool to expand the differential cover seal, so the circlip doesn't to any damage on the way through. So not knowing this will put you in my position.. Before returning the axle to the car, looked into the darkness and saw the seal spring hanging, with a small flattened section. So the seal was damaged on the pullout and now has to be replaced. After that a special Subaru tool has to be used to spread the seal before inserting the axle. Fortunately, this is an automatic, as if it were a standard trans, then the differential cover would have to be removed to replace the seal and this cover maintains the carrier preload adjustment...
So now have to order this tool $30.00 and shipping enough to get it here in a couple days to finish this one.. Not a happy camper...
