View Full Version : 63 avanti starter
charlotte1963
11-09-2014, 01:13 PM
what brand starter came on 63 avanti, my drive gear needs replacing, and napa shows a rebuild kit for about $25.00. would this fit my starter? tks chas/
Gunslinger
11-09-2014, 02:11 PM
It's a Prestolite starter. What model I don't know but the parts manual should specify that.
11-09-2014, 02:26 PM
MDU something. physically the same as any Stude V8 Prestolite starter - and that includes the "Bendix" (drive gear) unit. The Avanti version had more windings internally to deal with the higher compression of the R1.
SN-60
11-09-2014, 02:46 PM
That $25.00 price must be for bushings and brushes. The bendix drive you need would be considerably more.
charlotte1963
11-09-2014, 05:53 PM
tks for ur rply. i don't know. the pic show the drive unit. small price.if it fits prestolite go to napa web site item #ech srk104
rstrasser
11-09-2014, 06:04 PM
I have The Bendix drive listed as Bendix P?N 479006 and Prestolite P/N EBB-75 and Studebaker P/N 15500373
Ron
karterfred88
11-10-2014, 05:55 PM
Sorry won't work for the Avanti, need a Prestolite not Delco. SI has them new but should be able to find a rebuilt out there. The drive units are interchangeable with some 6 cylinders and I'm sure match some Ford out there. Pull it apart and compare with some other brands if price is a consideration. The drive assembly isn't bad to put on but needs to be right for the motor shaft, nose housing area, tooth count and diameter, or you'll ruin the ring gear--an even bigger PITA.
