View Full Version : In need of a tachometer
jimmijim8
11-05-2014, 08:31 PM
For a GT Hawk. tach, bezel and mounting bracket. Please, thank you chers jimmijim
jimmijim8
11-06-2014, 03:38 AM
bump 1234567890-
11-06-2014, 01:41 PM
I've got most of one somewhere, but am not sure if it's working. Do you have a sender? The one I have is the small brick solid state which has 6cy and 8 cyl posts.
jack vines
00RACER
11-06-2014, 04:23 PM
Private message sent
paul
jimmijim8
11-09-2014, 12:03 PM
bump234567890
JoeHall
11-09-2014, 01:22 PM
The retainer rings are same as for speedo and clocks, and turn up at most meets for $10-20 each. Less than a year ago, Tom K. had plenty of them for $15, but they were driver quality. If nothing else, SI has them for $45 each (part #1555431).
The mount bracket in the back may be harder to find, especially when looking for one, but I likely have one out in the garage. The OEM tachs are pathetic, when it comes to accuracy. I swapped mine out for a $60 Stewart Warner on feebay that looks close enough for me, and is much more accurate. I have the old OEM tach, but it's inaccuracy is unacceptable to me. I also have the rectangular sender, if I did not toss it.
You will also need a Lilliputian or two to install it (unless you remove the speedo to access it) :D
