Hi again, all,
I'm starting to run into more problems with my 63 Lark in the carb. It is a Stromberg WW 2Bbl and the engine is the 259 V8.
The other day, after driving about an hour in unseasonably cold weather (low 40's for this time of year) I shut the car off for about 3 hours. When I went back out and restarted it, the inlet valve once again acted up (failed to completely close) and the carb loaded up. I quickly stopped that by tapping the carb, inserting a screwdriver in the throat to keep the choke open and floored it and it quickly restarted and ran fine the rest of the day.
Today, I drove the car around 35 miles and it ran perfectly. Let it sit for about 30 minutes, hopped back in and took off. After a few minutes I noticed the engine seemed to be bogging when mildly accelerating during run (it idles fines and takes right off from a dead stop) but once began to feel like it was starving for fuel momentarily while leveling off from acceleration. Since then when I ease onto the throttle lightly while running, it stumbles, and bogs a bit. If it tramp down harder on the throttle it accelerates just fine, but as I level off, I feel it running unevenly as though the car is borderline starving. If I gently ease down on the gas it will stumble and bog even more, but if I throttle up more firmly, it responds beautifully. All the time it is idling just fine.
I have done a bit of reading, and there are suggestions that I rich up the idle screws a bit, and some comments seem to indicate it is not an accelerator pump issue. One person who is a carb tech indicated that normally fuel is run thru the idle jets even when cruising up to 2000RPM and if the idle mixture is too lean it will cause bogging like this on gentle accelerations.
I'm at a loss. The inlet valve is brand new - less than a month old. It should be seating and opening just fine. The float is adjusted correctly and is not hanging up. I am running about 8oz of Marvel Mystery Oil in the gas to keep everything lubed and smooth, and since using that have noted a nice little increase in power.
What do you guys think is going on? Should I richen up the idle screws a bit? Why would they suddenly go "out of adjustment" if that were the cause? This is getting very, very frustrating. I've rebuilt this carb once but have not completely eliminated the fuel problems - all of which began when we switched over to winter formulated gas! Should I just replace the carb with a rebuilt at this point?????????? Grrrrrrrrr!!!!!!!!!!!!!!!! :-(
Thanks,
-George-
Thanks,
-George-
