1- a 3x2 aluminum Cad. Weiand manifold but can be altered to fit Studebaker's this manifold is drilled for a carb with only 3 holes just like the 3 Strongberg 97's that come with the manifold, they need to be rebuilt you can not rebuild them if you don't own them here is your chance, plead note that there is cracks near the center bolt holes but can be welded, 3x2 manifolds are very hard to find so jump on this the carbs in rebuilding condition are worth the asking price of the set up. $1000.00 plus shipping and handling.
2- a nice pair of Weiand aluminum valve covers, nice condition $250.00 plus shipping and handling.
3- a small base 4 bld. carb for the early V-8 engines with a 4 bld manifold it is perfect if you have an early Offinhauser manifold with the small 4"x4" bolt pattern, $100.00 plus shipping.
4- a large bore altered 4 bld manifold, this was altered from an early style manifold with out the holes for the coil bracket. in nice shape and will preform better than a stock. $100.00 plus shipping weights about 30 lbs.
5- a stock 63-64 cast iron 4 bld. manifold for the AFB carb larger rear bores, $150.00 plus shipping and weights about 30 lbs.
