oil drain hole
  • oil drain hole
    Are both front and rear outboard (toward the exh manifold) oil holes functional on a v8.
    I'm working on a early 289 that both the front holes are stopped up. Looks like the oil returns thru the hollow dowel pin in the block.
    Thanks
    Russ
    57 SH (project)
    60 Lark VIII 2dr sd (driver)
    53 2R6 289 5SpdOD (driver)
    57 SH (project)
    Yes, that the hollow dowel pin in the rear is a drain, but the one in
    the front of the engine, I believe, is not a through hole.
    Tom
