I'm probably going to need to look for a new top frame assembly for my 1960 Lark (even my welded repairs have welded repairs at this point), but I see that the 1960 frame has some differences, the most significant one seems to be the front side rails. The other years seem to be all the same.
1. Am I stuck looking for a 1960 top, or will a later top fit as long as I'm replacing the entire frame?
2. Anyone have a 1960 frame they would part with?* (Just the metal frame, my pump and hydraulics are fine)
3. The book says to adjust the frame (without any rubbers or rubber holders attached) so there is a uniform 9/16th's inch gap between the frame and the top of the windows the entire length. The factory just put that in there for laughs, right? I can get close to that on the front window with full adjustment at the frame pivot point, but there's no way that's going to happen at the rear windows--there I'm doing good to get the window to even kiss the rubber, forget about a uniform 9/16th's gap. It's obvious that they tweeked the frame to make their top fit nice and tight, so I'm never going to get it adjusted properly without a new top, but even with a new top is that gap realistic?
4. My pump motor is protected by a 30amp fuse that keeps blowing because my twisted old top is making it work so hard. I can't find it on any schematic. Does 30 amp sound right?
Thanks
Jay
(*I know shipping will be a pain, but maybe you could just drop it at the nearest UPS Store and I'll pay them to pack and ship it?)
Thanks
Jay
