candbstudebakers
10-15-2014, 10:59 AM
# 11 is a pair of altered Offenhauser aluminum valve covers, some one has altered these a little but adding a tin strap to the inside area to help hold the gasket from sliding in and by dong that they drilled some small holes in the lower sides for small screws, you can see the screws in the picture but not the inside strap but it is the same strap used in early Studebaker covers, also noe of the covers has some of the ribs on top ground down some my guess to clear the long air tub used on some of the air cleaners used with 4 bld. carbs, but what you see is what you get for$100.00
http://i691.photobucket.com/albums/vv271/canbstudebakers/DSCN0073_zps627dcfb7.jpg (http://s691.photobucket.com/user/canbstudebakers/media/DSCN0073_zps627dcfb7.jpg.html)
The last item for now is a very rare early Cad 2x2 aluminum high rise intake manifold, this was made before they started using 4 bld manifolds, and as you can see on the edge it was built by Detroit racing equip for the 49 cad's very very rare , this item might need to be sold on e-bay to a Cad person, but it can also be altered to fit a Studebaker and since it is aluminum making the change would be easier than doing it with a cast iron one of later use type and a lot lighter than the cast ones, not cheap but very rare $1000.00
http://i691.photobucket.com/albums/vv271/canbstudebakers/DSCN0093_zps985ecbcf.jpg (http://s691.photobucket.com/user/canbstudebakers/media/DSCN0093_zps985ecbcf.jpg.html)
as before shipping and some handling will be extra, and first come first served.
