I have a very high ratio in my 1960 Champ 1/2 ton. It also needs brake work.
From all the research that I have been doing it almost sounds like it would be easier to find a axle with similar track width, 5x5 bolt pattern and the axle ratio that you want. its possible to even find one with rear discs.
I am not stranger to fab work so moving spring mount wouldn't be a problem.
Just sounds like you could pick up one from a salvage yard fairly cheap and then have a cheap and easy to service unit. IDK maybe im missing something
