I started a thread a week ago about my leaky transmission. Well, I pulled the trans and it appears to be leaking around the control shaft, the front pump seal and the rear seal. I figured I could do the o-rings and gaskets myself, but now?... Oh, the trans drove and shifted ok when last driven 3-4 years ago. '63 289 GT
Here's my problems:
1. I used a transmission jack that only contacted the flange, no weight on the pan itself. After I dropped the trans the input shaft will not turn regardless of where the shift lever is positioned. I'm not a trans guru but it seams to me that if the trans is in neutral the input shaft should be able to be turned by hand. I didn't try to turn it until I had it upside down on my workbench.
2. After cleaning years of crud off the case, I find the tail housing is aluminum and the trans case itself is cast iron. Is this the way the factory did it?
3. The aluminum tail housing casting has lots if tiny cracks, looking much like paint "crazing." They are sufficient to catch on the scraper blade I used in the de-crudding process. I've seen some lawn mower motor castings with some of the same thing, but this seems excessive.
Any thoughts?
Thanks
bhapner
Here's my problems:
Any thoughts?
Thanks
bhapner
