This is on my 63 Avanti, before I start ripping the entire driveline apart, maybe some others have had this noise and know where to start. When backing up or moving forward from a rest and attempting to go over a small bump, as into my garage, when I give it enough gas to "bounce" past it I get a "clang" or loud ringing sound from the drive line. I thought maybe it was the universal binding from excessive pinion angle, but it occurs going forward or backward, always when putting an extra strain to get moving. There seems to be a lot of lash in the rear end, noticed especially when putting it into gear from reverse to drive. All the mounts are new. I thought maybe the rear linings were hanging in the drums and "popping" loose but the seem fine and sounds of a ringing drive shaft shouldn't be transferred from the brakes anyway. Any ideas.
Rear end/Drive shaft "clang"
My guess is within a universal joint, probably bad bearings.
Do you have a pinion angle/driveshaft angle that is not stock? This can cause universal joint problems in forward and/or reverse.Gary L.
Originally posted by studegary View PostMy guess is within a universal joint, probably bad bearings.
Try bud's idea, look at the nut on the end of the axle, look for bright orange rust under it. If there's rust showing, that indicates movement, which should not be there. Take the brake drum/hub assembly off, clean inside and out (shaft and cavity) until shiny, do NOT lubricate it, and reassemble, being sure that the key goes in last, with the bevel toward the axle. Tighten to 170 ft lbs, then tighten until the cotter pin will go through.
What "Tom B" said.. I did find "key slop" on my Avanti on the left side. I checked out a new key on the axle (tight fit) and in the hub (loose). I purchased a new hub, got that all tightened down, checked the right one & it appears OK...
I still have the "clunk" when first accelerating forward... or backward. Pinion has been checked (I do not have Twin Traction), U-joints have been replaced as well. The transmission was rebuilt last year as well.
I don't know what to try next... so I just drive it, living with a "clunk" when changing directions.
Originally posted by Deaf Mute View PostWhat "Tom B" said.. I did find "key slop" on my Avanti on the left side. I checked out a new key on the axle (tight fit) and in the hub (loose). I purchased a new hub, got that all tightened down, checked the right one & it appears OK...
