For my son's 62 Lark 289 V8, automatic (which used to be my car for 10 years), he is having the following problem. He says the car starts and runs a minute and then quits, it can be repeated start, run, quit. My guess is fuel delivery. He thinks it is the carb. Anyway suggestions and opinions are welcomed. He wants to get this car back on the road and use it for a back up car for work. Thanks for the help.
62 Lark Issues
Tags: None
In the off chance that you have converted to the Mopar EI, it may need the resistor replaced.Brad Johnson,
'56 Sky Hawk in process
Originally posted by rkapteyn View PostIf the gas cap is not a vented type it will create a vacuum in the tank and the car quits running.
Try to run it without the gas cap and if it keeps running you know what is wrong.
Robert Kapteyn
He ran the car a few months ago. He drove it his work 50 miles away. (This story was in Turning Wheels a few years ago). I am suspecting that the rubber part of the fuel lines may be a problem. I'll know when I see him.David G. Nittler
Another possible problem is a pin hole in the fuel line, most likely behind the clamp that holds the tube to the frame above the rear axle. I had exactly the same symptoms with a 59 Lark. It was most likely to manifest itself when going above 30 mph or up hill -- when the fuel pump was pulling the most vacuum. It never leaked enough to drip on the ground, but allowed plenty of air to get into the line when the engine was running.Skip Lackie
