We have a 62 T cab here with an OHV six. After sitting for some time without being run, the engine would not start. I figured that the gasoline had evaporated in the carb and took it apart and cleaned everything. After a careful reassembly the engine would only run on gas poured into the carb. I took the carb off and rechecked everything, but still the engine would not run. I took the inlet pipe off and gas ran out, so I knew the fuel was getting that far. When I removed the fitting with the needle, the inside was dry. The needle was stuck to the seat! I cleaned the needle and reconnected the line. The truck now runs again.
A stuck needle was not the original problem because the engine would respond to the fuel accelerator pump before. The needle stuck while I had the carb off and introduced a new problem. I'm glad that I didn't tear the thing apart again.
