Back in July, I sand blasted and painted the frame of my Hawk along with all of the suspension parts that were removed. While I was into the process, I also blasted and painted my Dana 44 rear end. I had just gone through the rear end and replaced all the seals and gaskets along with a flanged axle kit from Fairborn. During blasting, the crud was blown out of the little vent hole that I didn't know was there until it was cleaned out. Obviously the crud that was in the vent hole along with an unknown amount of sand was blown into the axle tube. I knew I had to pull the axle on that side to clean out what ever got inside, but I had to wait until the rear end was back in the car because the dolly I built supported the rear end from the axle flanges. Fast forward to today.
The rear end is now back in and supported by the springs so tonight I decided to pull the axle and see what was in the tube. The tube didn't have much in it but the grease around the bearings was full of sand. Prior to blasting I taped the outer grease seal housing to the axle to prevent sand from getting through the felt seal. The tape appeared to hold well. When pulling the axle I discovered sand between the outer seal housing and the brake backing plate. I seems that the sand blaster had enough pressure to push sand between the seal housing and backing plate.
So now my problem is how to clean everything up prior to re-assembly. I would like to remove the bearings from the shaft so I can clean them really well. The manual just says to use a press but I don't know to get a grip on the bearing to press it out. Anybody have a simple explanation or picture showing the removal of the bearings from the shaft.
As for cleaning the crap out of the tube, anyone have any advice on how to flush the tube? Is the tube open into the diff housing? If I remove the rear cover can I flush the tube with diesel and have it drain out of the diff housing?
Thanks
Wayne
Thanks
Wayne
