I ran a check yesterday on my charging system in my 63 Lark and found the charge rate is 13.8 volts steady. From what I have read, normal charging rates are between 13.8 and 14.8 volts, so yes, I'm in the range but would prefer the rate to be slightly higher within that range.
The Shop Manual addresses adjusting Autolite regulators for generators, but does not address Prestolite regulators for the newer alternator systems, and looking around on the Internet I have found conflicting information as to whether or not mechanical regulators for alternator charging systems can be adjusted. Anyone know the answer to this??
And I suppose the other question would be: is my 13.8 volt charge rate sufficient and should I just forget about it???
George
George
