My 63 Avanti continues to be a pain in the rear. On previous postings I was finally able to get the hoses to work, but I immediately started getting leaks from the control valve housing, once working. Since the valve assembly appears to have been rebuilt, possibly by a Ford guy as it is painted aqua, but appears to be Studebaker from the outside, I ordered new seals from SI and installed. The old seals were hard as a rock and broke coming out but didn't pour fluid past them. The new ones w
orked great for about 2 miles. First the cap screws started to drip. Then after sitting in the garage while working on brake problems, more drips started, now from the flange where the pitman ball sleeve attaches. I believe the new seals are not working. I pulled the cap and spool out and checked the direction of the lips on the seal and they are correctly installed. The spool itself looks excellent, maybe too good for its age. I'm wondering if it was swapped with one from some Ford unit and therefore my new seals aren't going to work, or it was machined and some substitute seals used. Can't tell by fit as it feels good in the housing and the housing is correct for Studebaker. Anyone know of a source for different size seals that I could try without going through 10 kits. Is there some kind of reference with the spool dimensions on the shaft so I can find out if I'm fighting a lost cause. I've looked at other posts but there was no follow up on their resolution, one of which showed no relief holes in the Mustang replacement spool, and then just had the ends of the original machined smooth, but no mention if the original size seals were used or a substitute with a smaller ID. From the way the seals fit and feel in the housing I'm pretty sure the fluid bypass is on the inner id of the seal at the spool itself. HELP !!!!
Fred
orked great for about 2 miles. First the cap screws started to drip. Then after sitting in the garage while working on brake problems, more drips started, now from the flange where the pitman ball sleeve attaches. I believe the new seals are not working. I pulled the cap and spool out and checked the direction of the lips on the seal and they are correctly installed. The spool itself looks excellent, maybe too good for its age. I'm wondering if it was swapped with one from some Ford unit and therefore my new seals aren't going to work, or it was machined and some substitute seals used. Can't tell by fit as it feels good in the housing and the housing is correct for Studebaker. Anyone know of a source for different size seals that I could try without going through 10 kits. Is there some kind of reference with the spool dimensions on the shaft so I can find out if I'm fighting a lost cause. I've looked at other posts but there was no follow up on their resolution, one of which showed no relief holes in the Mustang replacement spool, and then just had the ends of the original machined smooth, but no mention if the original size seals were used or a substitute with a smaller ID. From the way the seals fit and feel in the housing I'm pretty sure the fluid bypass is on the inner id of the seal at the spool itself. HELP !!!!Fred
