There has been a bit of talk on the Forum lately about flanged axles and I had posted a thread a couple of weeks back as I was looking for flanged axle parts. I have learned some interesting things along the way. So, I thought I would share. When Stude switched to flanged axle shafts on the late 65 and 66 "Lark type" cars, they used the same axle shafts for both the Dana 27 and 44 axles. Both setups also have the same seals, bearings and retainers. As many have noted before me the outer oil seals are (almost) "unobtanium". The tapered cone and roller bearings are different than on the tapered axle shafts of similar vintage Stude cars, but the cone to mate with the bearings are identical. I also note that the bearing cone and rollers and the cones are still readily available. The bearings on the flanged axles require a "bearing retaining ring" P/N 1562427 - this is the part that I have not been able to find despite best efforts at trying most of our well (and lesser) known Stude vendors (and some recommended bearing suppliers). This is puzzling as a new bearing set without a retaining ring is pretty much useless - unless you can figure out a creative way to reuse the retaining rings (The Stude Service Manual advises to cold chisel them off the shaft to replace the bearing). I do have the size now, so I can search a local supply to see if I can find something that will work.
The most interesting bit of information (to me) was the inside bearing diameter - Studebaker used a bearing with an ID of 1.3125". When I checked various Fords, Internationals, Jeeps, etc. that used the Dana 27 and 44 axles - also with flanged shafts they all used bearings with larger ID's usually around 1.5" to 1.75". It is the smaller diameter that is causing the difficulty in finding matching parts. Given Studebakers limited production of flanged axle cars, it is curious why they would not have adopted a more "standard" size of shaft diameter used by many other manufacturers. I am thinking there must be another car maker that used these smaller diameter shafts and bearings.
Also, the listing in many flaps for the flanged axle wheel bearing comes out as a cone and roller bearing for an input shaft on a manual transmission - another interesting adaptation.
BTW, I'll give a plug to S.I. as they actually have complete flanged axle shafts for these cars in stock with a complete bearing, retainer and seal set already installed ready for installation in the vehicle - always an option I suppose if I cannot find a couple of $5 retaining rings...
In the meantime, I will continue to drive my "tapered axle" Transtar.
