How is the front end of the factory installed traction bars mounted? The 62 Gt frame that I got to replace my 64 has what looks like a shock mount welded onto the outside of the frame rail almost where the front spring mount is. Not sure if thats what this is or if its just something someone welded on there that needs to be cut back off.
Traction bars
Tags: None
Thanks Deepnhock. What I have is like the front mount on post 12 by studebaker r2-4 me. It looks like a stud for a shock welded to a plate and then welded to the frame close to the front spring mount. There is no rear end in it so the mount on top of the rear end and the bar its self is not there. But after looking at that post I think I could build both of those. Not sure if that set up is a factory aftermarket peice or just something someone added on. This was a frame from a 4sp car so I can see why someone would want to put some kind of bar on it.
Is this the mount that you have welded to the 4 speed frame?
If so, all the other peices for the traction bars are available from Phil Harris
As for making up the radius bars you should note that there are slight angles in the ends to create the offset from the frame to the axle mount.
Allen1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
Originally posted by swvalcon View PostThis car is only a 210 hp so to much power is not a problem. It's either cut them off or get the rest of the parts and leave as is.
Leave it on,... it will be there when someone wants to add another 80+ HP
Allen1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
Well as you can see from the correct Traction Bar Pics, this is a shadetree installation complete with those phony spring clamps.
It also appears this Car has 259 or Brand X Rear Brake Drums, not correct 289 Finned type used on all 289 equipped Cars and some kind of Brand "X" Rear Axle.StudeRich
Sorry Alan, I got you and swvalcon mixed up, those are great looking Urethane? Spring Bushings, are they stock for a brand X or had to be "Made"? No doubt described in a former post.StudeRich
Yes, there is a post somewhere around here about UHMW plastic. It is slightly harder than urethane but softer than nylon and not as squishy as Teflon. That is a 57-58 Ford 9" with 2" X 11" drum brakes. Converting it over to discs. The springs are from a 65-66 Dodge Ramcharger, shortened and re-rolled on the rear eye. So everything has to be custom made.
What does the traction bars do to ride quality in the GT? I knew a guy with a 56J that had them, and it rode like a road wagon. When he took them off, it rode like a 56J again. They anchored to the bottom of the frame rail, instead of the side as this GT does.
[/URL]
[/URL]
