1953 / 1954 Stude Coupe Roof
  • 1953 / 1954 Stude Coupe Roof
    Any information as how to remove a roof on a 1953 / 54 coupe for replacement, please advise , Photo's would be a great help, Thanks
    garnsej@sbcglobal.net
    James Garnsey
    I believe the factory recommended method would be to replace the body![:0]
    Studebakers Northwest
    Ferndale, WA
      Ferndale, WA
        Street rodder, rod & custom type magazines have articles on cutting and chopping the roof. Lots of pictures and information. You can't use too many braces on the body to keep the shape correct. Have fun.
            It can be done but that is something only an experienced body man should attempt.
            Analog man in a digital world.
                I take it from your question James, that you either have serious metal damage, or rust issues with your roof section.
                This would be a major repair to most Stude owners, and many would just find a suitable replacement body tub.
                If you did find a suitable replacement, then cutting the old one off would not be impossible, but it would be tedious.
                The most important thing would be to stabilize the body in a 'square' position so it can't move during the replacement process (with bracing welded in as mentioned here on other replies.
                A good body shop with frame straightening equipment could do this for you, but at today's labor rates it will be quite expensive.
                Without more information in your question post, you will be getting a variety of answers.
                Try and ask a more specific question as to what you are starting with, and where you want to go with this project.
                James Garnsey
                  James Garnsey
                    Thanks for the reply sounds like it not going to be an easy fix .
                    James Garnsey
                    James Garnsey
                      James Garnsey
                      James Garnsey
                        James,
                        It's NOT that hard to do! Get all of the trim off including headliner and interior. Look around the edges for spot welds, first drill them out with an 1/8" drill bit, then buy a good spot weld drill bit, (might need 3 or 4) Most of the welds are pinch welds and will drill out easily. the hardest part will be the sean at the 1/4 panel. that you will have to melt out the body lead, and look for the seams. After the hail storm here in Indy last year, we must have put on a hundred roofs on the newer cars.
                        Jim
                        their Memorials!
                          James,
                          Jim
                          their Memorials!
                            Makes me wince to think about the TWO coupe roofs I sent to scrap metal awhile back. Hated to do it, but since they're the last thing to rust out, I decided they'd never find a use in my lifetime.[V]
                            Miscreant adrift in
                            the BerStuda Triangle
                              Miscreant adrift in
