View Full Version : GT Hawk ignition switch
R2GTHAWK
09-26-2006, 08:22 PM
Thanks for the information on detailing the underside of my Hawk.
I have ordered Eastwood Chassis Black paint and I will put a yellow
stripe on my front springs.
I have a new problem. When I tried to start the car this morning,
I somehow unlocked the bezel from the ignition switch and I am having
great difficulty trying to push the switch in with the spring working against me. Is there a trick to this or do I have to remove the dash to do it? I tried to look up dash removal in the manual, but there isn't much info about Hawk dashes. Any help would be greatly appreciated. Thanks in advance for your advice.
JDP
09-26-2006, 10:33 PM
It's a bitch, but no need to remove the dash. Push the switch in hard against the dash and twist the bezel on to the tabs. BTW, chech the bezel to make sure the tabs are not broken off.
http://stude.com/sig.jpg
Studebaker On The Net
http://stude.com
Studebaker News Group
Arnold Md.
65 Sports Sedan(sold)
64 Daytona HT
63 R2 4 speed GT Hawk
63 GT Hawk
63 Avanti R1/AC
63 Avanti R2/4 speed
63 Daytona HT
63 Lark 2 dr.
62 Lark 2 door
62 GT(parts car)
60 Lark convert
60 Hawk
57 Silver Hawk
52 Starliner(sold)
51 Commander
50 Champion (sold)
kmul221
09-27-2006, 06:36 PM
You also have a bit more room to manouver if You undo the hood release cable & move it to one side
starlightchamp
09-27-2006, 07:01 PM
A good idea while the switch is out-tape over the terminals in back. I disconnect the battery
before removing or replacing the ignition switch. Removing the Hood Release bracket as described above is a near must! Test fit the bezel barrel and see that the slots index easily into the small bosses and adjust until they are a little snug. The job is easier if you can find a helper to insert and twist the bezel while you hold the switch barrel against the spring tension.
Good luck!~
Dick Curtis
1950 Champion Starlight
1963 Hawk GT
Santa Barbara
CA
John Kirchhoff
09-27-2006, 10:17 PM
The switch on my '60 has two different sized slots. The inside top of the bezel has a hole in it for light to shine through from the bulb located above. If the hole is on the bottom but the switch itself is still right side up, it won't go together. That's one I learned the hard way!
