I have a problem with blowing fuses in my '64 Champ. The fuse in question is the one which affects the brake and interior lights. I will not drive the truck until I get this figured out. I disconnected the interior bulb to isolate that as a possible cause-blew a fuse! I then disconnected a wire from the brake light switch on the MC-blew another fuse. I also deactivated the glove box light I am in the process of tracing the black wire from the post which appears to go into the harness, possibly the turn signal switch. Could the turn signal switch be the culprit? Could I have a short in the column wiring? I might add that when my Dad and I rebuilt the Champ we installed gauges from a '63 Daytona along with the speedo by hogging out the bezel. All has been good for many years-until now. Your thoughts are welcome before I tear out even more of my thinning hair.
Rob in PA.
Rob in PA.
