Posting here since not about a stude....
I've had my old '87 Ford Ranger truck sitting at the farm in the old cattle shed for 10yrs. I think I last started it about 2006... So, this past week while I was down there I tried to get it going so I could move it as the tires had sunk into the dirt up to the rims. Definitely not ideal storage location.
After about 10gal of fresh gas and 1 can of seafoam I managed to get it running enough to determine its got some intermittently sticking valves. Eventually, I had to hook a tow rope to pull it out of its sunken holes but was then able to drive it around the yard. When sticking, it won't stay running w/o pumping the gas and it shudders badly. When not totally sticking, you can hear it coughing in the exhaust to greater or lesser degrees.
Any suggestions on magic potions to get those valve(s) unstuck? The oil was changed back when it was parked and it still looks clean. This truck has the 2.9 V6. It WAS running OK when parked so I can only assume this problem came about from sitting so long. I had it running on 3 occasions over the week long enough to get up to operating temps and it didn't clear up. Seems better when warmed up and worse at cold start.
At least I was able to get it moved and repositioned back in the shed. Some other stuff in that shed is going to be a bigger challenge.
