View Full Version : Ignition: Interpreting timing mark
hawkjockey
08-09-2014, 03:56 PM
Have a crank wheel with a yellow stripe painted for timing. Looks factory. Pointer is set on bottom of yellow stripe during timing check. Should it be in the middle, top or bottom? Thanks!
Bud
08-09-2014, 04:36 PM
What engine are you working on as the timing marks aren't the same for all of the Studebaker engines? Bud
hawkjockey
08-15-2014, 04:55 PM
V8, 289ci, 2 bbl
08-15-2014, 05:05 PM
If the "mark" is on the "IGN" fine LINE to the Right of the UDC (0) Mark, that is where the pointer should be, ON the Line that would be 4 Degrees factory setting but it may run better advanced more with current Fuel, like 6 or 8 degrees you have to guess at that as there are no other marks unless you use a "Setback" adjustable Timing Light.
willisl55
08-26-2014, 04:49 PM
is advance toward the UDC(0) mark or toward the IN-OP line.
Thanks
Lee
tbredehoft
08-26-2014, 04:53 PM
Advance would be away from the UDC,
