I have read that the Hawk uses a Hurst 391-5403 shifter with a 373-4734 kit. And that this combination maybe used for an Avanti also. (though I have read that the 3-4 rod in the linkage kit may not be correct).
That being the case, which shift handle will exit through the stock area of the console correctly?
If I use a Hurst shift handle, then I would need to have a different boot or have a stock handle welded to the Hurst base to preserve the factory boot.
63 Avanti R2, 4-Speed, 3.73 TT
Martinez, CA
Martinez, CA
