New Brake Line Fittings - '63 Avanti
I have found that some "Other Makes" have deeper Master Cylinder or Wheel Cylinder compression Nut locations apparently, because the line nuts for those on Newer Lines or Kits have more threads (longer) I think maybe this is what you are experiencing, and no it should not matter where they go on a Stude.StudeRich
I have in stock the correct 1/2 x 20 flare fitting that will accept the 3/16" line, to go directly into the M/C, eliminating any need for adapters. I also have the 9/16 x 18 fitting for the 3/16" line. Makes a much cleaner installation.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
