1965 Daytona Sport Sedan
Tags: None
Yes, lub the cable core before inserting it in the outer sheath, even if the part you purchased is a complete cable (inner, removable core and outer protective sheath). If only purchasing the inner core and you have the outer sheath removed, try to wash the old gummy or caked lub out of the outer sheath. Then, lub the new core, and move it back and forth in the housing to work some new lub into the sheath. Check to make sure the outer sheath is not kinked or smashed somewhere along its length. Turn the speedometer by hand by turning the part where the cable attaches to make sure the speedometer and odometer are turning freely. ~ Dale
Originally posted by blackhawk View PostYes, lub the cable core before inserting it in the outer sheath, even if the part you purchased is a complete cable (inner, removable core and outer protective sheath). If only purchasing the inner core and you have the outer sheath removed, try to wash the old gummy or caked lub out of the outer sheath. Then, lub the new core, and move it back and forth in the housing to work some new lub into the sheath. Check to make sure the outer sheath is not kinked or smashed somewhere along its length. Turn the speedometer by hand by turning the part where the cable attaches to make sure the speedometer and odometer are turning freely. ~ Dale
Welcome to the SDC Forum!
Your car is a Daytona Sports Sedan.Gary L.
Many Thanks to blackhawk and studegary. I mentioned this to my young mechanic when he put the first complete cable in but he said it was a "sealed" unit and put it in without any extra lube. If one of you would care to elaborate a little, how should he go about taking it apart to lube the new one I have. Service manual was no help to us with this particular item.
Dick-- If you climb under the dash and remove the speedo, take it over to your workbench and GENTLY pry back the tabs holding the case together. Remove the speedo mechanism from the case. There is, as I recall, a hole in the bushing that surrounds the cable input shaft. That is a lubrication hole. Try to get some penetrant in there. The best penetrant BY FAR is a mix of acetone and ATF, 50/50. Let it sit a bit, then try to free it up as follows: grab an old #2 Robertson screwdriver tip. You may have to carefully grind it a little, but you can make a speedo "driver" out of it. Chuck it into your electric drill, and use it to spin the speedo. After it frees up, then lube that hole with aerosol lithium grease (WD-40 brand makes some, so does Liquid Wrench brand). Make sure it's Lithium Grease, not penetrating oil. Work it in, using your home-made drill-driver. Reassemble and install. THIS is why you were breaking cables... Oh, and be sure to soak the wick inside that holds lubricant for an extended time.1950 Commander Land Cruiser
1951 Champion Business Coupe
1951 Commander Starlight
1952 Champion 2Dr. Sedan
1953 Champion Starlight
1953 Commander Starliner
1953 2R5
1956 Golden Hawk Jet Streak
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1962 Cruiser 4 speed
1963 Daytona Convertible
1964 Daytona R2 4 speed
1965 Cruiser
1970 Avanti
