Hi guys,
Well I ran into a little bump in installing my new hoses. All the prior hose routing posts, as helpful as they were seem to deal with 64 and up Avanti. As you know the left apron and battery box area is different on the early ones. Well, as the old hoses were "home made" to be polite and were routed pretty much as described in the earlier posts, I went to put the new pressure hose on the pump and remount the pump assuming the hose would fall naturally where it should go--wrong. As I tried to show in the photos, it wants to go either down to the cross member or, if coaxed way up in the air and around the regulator. There are no signs of any clip mount areas except at the top flat area behind the regulator, nothing else. Any ideas where to route it? Or should I re-bend the "L in the hose to make it work!"
