My son and I are attempting our first brake rebuild on his 57 C cab pickup. Everything has gone well until we tried to get the right rear brake drum back on. No matter how we tried to adjust the shoes the drum just won't slip on. Is there a "trick" we are missing? Please give us some help.
Brake rebuild
Is there a 'lip' on the lip of the brake shoe surface on the drum?
Did you have the drum 'trued'?
Are your linings 'std', or 'oversize'?
'Oversize' linings ate just thicker friction material, intended to be used on drums that have beeb 'turned' and have a larger ID than stock.
Remember that there is an .060" max diameter increase allowed by law on brake drum turning.
I am sure others will chime in with some other things to look at.HTIH (Hope The Info Helps)
Try loosening up your emergency brake cable,
Originally posted by richt View PostMy son and I are attempting our first brake rebuild on his 57 C cab pickup. Everything has gone well until we tried to get the right rear brake drum back on. No matter how we tried to adjust the shoes the drum just won't slip on. Is there a "trick" we are missing? Please give us some help.
53 2R6 289 5SpdOD (driver)
57 SH (project)
60 Lark VIII 2dr sd (driver)
