After finally finding my hub puller I started to pull the drums to check the brakes. One side came off in a few minutes but, the other was a problem. One stud was broke and I manage to strip the other, I think I did not tighten it down enough and the nut came off. My question is there a way to tighten another bolt on there or some other way to get the drum off so I can replace the broken stud as well as the stripped one.
Stripped stud
Tags: None
Simple. Buy 10 new studs, go to your local car repair mechanic (not the name brand car shops) I payed $75 to press out and press in the new studs. They need to a have a multi-ton press. Do not let them beat the studs out with a hand sledge. Call any of the forums suppliers for new studs.Last edited by Studebaker1962; 07-12-2014, 08:17 AM.Studebaker1962
