The Hawk became hard to start and was smoking. Twice it died and would not restart. Both times it restarted after about 15 minutes of setting. I had gas in the oil. The fuel pump diaphragm broke so I installed an electric fuel pump and again it died and would not start. I checked the fuel line back to the tank. When I disconnected the line between the tank and pump no fuel came out. I blew compressed air I the line and gas came out. A few days later the same thing happened. I blew on the line and fuel started. Today I removed the sending unit and cleaned out the tank. The fuel tube has two small holes near the end like something should be attached. I can't find a picture of what it should look like. Used a small hose on a shop vac to vacuum the inside. It is clean. When I drained the fuel it was clean. Put it back together. Started it and let it run about 15 minutes before driving. Got about 1/4 mile and it died. We pushed it back and put compressed air in the line then the fuel flowed. Ran 15 minutes then on the road, I got about a mile. I got my truck and compressor but this time when I blew in the line nothing came out. Added 5 gallons of gas. Nothing came out. During this each time I blew in the line I would attach the line and let the fuel pump run. When it worked I could see the pump push gas into the fuel filter near the carb. I used a gas can and ran a line from the can to the pump. Turned the switch and gas pumped into the fuel filter. Drove it home and there it sets.
Seems like my options are a new sending unit with the fuel pipe...if I can find one, or drop the tank and take it somewhere to install a fuel connector in the tank. Any ideas?
