View Full Version : R1 Carb Filter
2R5
07-07-2014, 04:00 PM
Anyone have the dimensions for the cartridge for the chrome R 1 air filter?
Gunslinger
07-07-2014, 04:56 PM
I don't have the dimensions but when I owned a '63 R1, it used the same air filter element as my '64 Pontiac Bonneville 389 4-barrel.
2R5
07-07-2014, 05:01 PM
Thanks , but that's not good enough for my local FLAP store . I also was told that a Ford 289 HP filter is the same but they told me they need measurements in order to match me up .
Flashback
07-07-2014, 05:08 PM
I can measure one in the shop when I get home tonight, if you don't do better fore then.
rstrasser
07-07-2014, 05:09 PM
Old stock # Purolator AFP-80
2 3/16 Height 13 1/4 Diameter Filter material about 1 inch thick
That is as close as I can measure the filter
Ron
07-07-2014, 05:26 PM
Really, is it so hard for them to just look up a Police Interceptor 406 '64 Ford or one of MANY Hi-Performance Fords using that Element? :mad:
2R5
07-07-2014, 05:42 PM
Ron
Thanks guys ....Appreciated !
bezhawk
07-07-2014, 05:56 PM
Really, is it so hard for them to just look up a Police Interceptor 406 '64 Ford or one of MANY Hi-Performance Fords using that Element? :mad:Yes, it is.....that is ALSO 50 years old. Most FLAPS don't and won't want to list anything other than what sells well.
It's a fact of life, if you are in the old car business, then you HAVE to be YOUR OWN PARTS PERSON . In other words it's up to you to research what fits and doesn't fit, AND THE CURRENT PART NUMBERS.
If you find a parts store wiling to look in books, and cross references for you, then you are in the MINORITY.
Stu63
07-07-2014, 07:19 PM
The K&N E-1560 is supposed to be a direct fit for the R-1 air cleaner
SScopelli
07-08-2014, 12:07 PM
WIX 42063, NAPA 2063, or Fram CA-114 also work.
Or if you do a search on the forum you get this link..
http://forum.studebakerdriversclub.com/showthread.php?864-R1-Avanti-air-filter-number-and-oil-change-time!
