Help Transmission Rear Oil Seal
  • Transmission / Overdrive: Help Transmission Rear Oil Seal
    Hi guys. Need some ideas on how to remove the rear oil seal on my A/T. A PO installed the seal backwards. The tranny is
    in a "70" Avanti II and the "X" member comes into play. Any ideas will be greatly appreciated.
    Jim Barker
    '70' Avanti II
    I have a long handled seal remover that worked on my 63 Daytona convert, about the same X member problem, come on by and get it!
    Frank van Doorn
    Omaha, Ne.
    1962 GT Hawk 289 4 speed
      Hi Frank. The problem is with the seal being in backwards. With the seal seated backwards there is no lip for the puller to latch onto.
      Frank, I have to leave for a while, promised the wife I'd take her to Bed, Bath and Beyond-------coming dear.
      I'll talk to you later.
      Jim Barker
      '70' Avanti II
        Call me later and I will explain how to use it. The tool gets in behind the seal, so it does not matter if it in backwards. Yes "Honey do" things have priority.
        Frank van Doorn
        Omaha, Ne.
          I replaced the rear bushing and seal on Raymond Loweys 76 Avanti. After removing the grive shaft, I unbolter the transmission extension housing and slid it rearwards, and off the trans. Made replacement really much more convienient.
          Bez Auto Alchemy
            bezhawk was Loweys Transmission a B/W Powershift?
            Jim Barker
            '70' Avanti II
              How difficult is it to replace the extension housing bushing along with the seal?
              1970 Avanti (SBC, R3)
                No his LAST Avanti was a 76, and had a turbo-hydramatic 400. If you don't have a press most machine shops will replace your bushing for a nominal cost.
                Bez Auto Alchemy
