Hi first time posting. Long story short, my in-laws are moving from their house of 40+ yrs and in the field where several vehicles. But my wife had her eye on this one. I admit I was reluctant but once I got it out, aired up the tire and cleaned the debris off it, I have a complete truck. 1949 2R10. Minus some trim and couple of nobs in the interior its all there. But now what do I do with it? Any one have a thought as to what's the value of this truck? Is there anyone in the Las Vegas area to go to? Thanks,
Pulled from the field today, 1949 2R10-22 Truck
Originally posted by benkaissa View PostBut now what do I do with it?
We know they can be made to run! Before that attempt I would make certain it can be made to stop! BRAKES FIRST ! ALWAYS ! Better no go than no whoa!
To that end, here is a great primer for putting any old vehicle back on the road.
It's got some major dings and dents but the critical areas usually rusted out look to be intact--homage no doubt to Nevada weather.
Also looks like it had the caravan bed cover at some point. If it's safely functioning and legal, it could be great fun, a functional truck and a real attention getter, especially on the strip! JDP may even want to use it to haul his chips!
Restoration could always come later if desired; or by someone else, if desired. Anyone interested in buying it will pay you more for one they can drive home.Last edited by rockne10; 06-23-2014, 09:26 PM.Brad Johnson,
'56 Sky Hawk in process
Welcome to the forum Ben! May I suggest what has been posted off the Club main page. Up top here click on the Studebaker Drivers Club home page, then click on under "new to Studebakers" the word "about" (I think that's it... I did it once here but when I tried going back to make sure it wont connect) then look for "tips & tech, ect" & you'll find a topic "things to do when you get your first Studebaker" or something to that affect. It contains a list of things in a logical order so that your new ownership will be a happy one. Don't forget us here either. We are happy to help whenever we can!Last edited by Warren Webb; 06-23-2014, 09:51 PM.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Wasn't that this, Warren?
Originally posted by rockne10 View PostTo that end, here is a great primer for putting any old vehicle back on the road.
Brad Johnson,
Your right Brad. I missed the link you posted that takes one directly to there. Blame it on a brain fart!59 Lark wagon, now V-8, H.D. auto!
64 Zip Van
66 Cruiser V-8 auto
If your truck were found in that condition here in NJ, it would be in high demand.
Very cool truck, hope you fix her up. Fix the brakes first if motor checks out!
Hit my father in laws sail boat with my Packard when the front brake hose let loose!sigpic1957 Packard Clipper Country Sedan
Lt. Col. Jimmy Doolittle
Very important, since I don't know your age and experience...make sure you use a six-volt battery and connect the positive post to ground! Unless that truck was changed to twelve volt...that is the kind of electrical system it has.
Yup 6 volts. I've owned a few older vehicles and am a decent mechanic. Also I know my limits. So dad says that there was a "rod" going out on it and thats why it was parked in the mid 70's. If it needs rod bearings how big a job is that? One more question. I can not get the right rear wheel to turn. I pulled the wheel pulled the axle and made sure the ebrake is released. Do I need the drum puller for this model? Thanks.
Rod and main bearings are easily located. If you have plans to keep it, I'd pull the engine and go through. Job isn't as expensive as some would think. If it is known to have a rod noise, I'd see if will turn over but not start it for fear of further damage. If you had old cars, then you'd know the fun and excitement of driving something no one else has.
Kim
Successfully pulled the right rear drum. Not too rusty. Brake shoes look really good. This so far has been quite a find. I also talked to Donald at Lark works (thanks for the speedy quote btw) and a new wire harness will be ordered soon. Looking for a key set now as the originals MIA.
