My 61 lark six cylinder, automatic, has the follow problem. At a car show in May I bought some bad fuel and that resulted in the car running badly and quitting. Any way I took care of the problem, including removing the bad fuel, and it worked until today. (But without much use)
Today the car would sputter and barely move or accelerate. I did get it home, and checked the usual items: the carb, fuel filter, plugs, points distributor, etc. I started it up and it ran badly and then it picked up and ran fine.
My conclusion is that the fuel must be absorbing moisture and causing problems.
So my questions would be what additives(s) would you recommend so the I can cure this problem?
What are your opinions about Marvel Mystery Oil, Sea Foam, Heet, and so on.
Notes: The motor is rebuilt with 7000 problem free miles on it. The valves were checked and adjusted, and I do not think any "big stuff" is messed up.
Your thoughts are appreciated.
