I know this is a shot in the dark but.......Does anyone know the approximate weight of the body for a 1960 Lark Hardtop? I'm looking at removing the body from the frame to make some frame/suspension improvements and I'll probably be raising it in the air from the rafters in my garage. Then setting it on some steel stands while I work on the frame. I'm looking for the weight of just the body minus the doors and front clip if possible.
Fatty Tissue
I've done it. But like StudeRich said, good vertical and horizontal support on both sides of the body to spread the load is a must.Last edited by Lanny Bertram; 06-12-2014, 09:25 AM.sigpic
Lanny & Barb Bertram
'63 Lark Custom R2 4spd
Indy Chapter SDC since 2000
Weaverville, NC
Actually I didn't say that Lanny, but that is a very good suggestion and REQUIRED to reinforce the Door openings on Hardtops and Convertibles especially, if doors are removed to prevent distorting the very weak body, once it is off of the Frame.
You will want to SEE this:
http://forum.studebakerdriversclub.c...lity-Build-offStudeRich
I don't know what the weight is, but it's not as heavy as you think. I just lifted the body off with 4 guys, and it wasn't even a struggle.
Mine sat on simple sawhorses for 2 years while the trunk, rockers, floor and sub-flooring got replaced.
I never thought to brace the body until later on. So I was very happy when the car went back together that the doors actually fit! I would be more careful if doing it again.
