I have a 1960 Lark 232 engine with a McCullough supercharger. It currently has an electric switch to control the supercharger. My switch is worn out looking to replace it. Found a picture on line showing a manifold vacuum switch, which has 12 volt power and a single vacuum line.The vacuum switch would be normally open circuit then closed under vacuum off idle. Where can I find a vacuum switch.
Manifold vacuum switch for McCulloch supercharger.
You may find that the vacuum switch is too sensitive for the supercharger solenoid to keep up with. You might want some sort of time delay so the supercharger doesn't constantly switch pulley width.
Perhaps some sort of metered restriction in the vacuum line?Last edited by bezhawk; 06-11-2014, 06:09 PM.Bez Auto Alchemy
Originally posted by studee View PostI have a 1960 Lark 232 engine with a McCullough supercharger. It currently has an electric switch to control the supercharger. My switch is worn out looking to replace it. Found a picture on line showing a manifold vacuum switch, which has 12 volt power and a single vacuum line.The vacuum switch would be normally open circuit then closed under vacuum off idle. Where can I find a vacuum switch.
