View Full Version : Parting out a 1960 Lark Two Door Wagon
61Lark
06-10-2014, 06:46 PM
This summer we will be parting out a 1960 Lark VI 2 Door Wagon. Its a typical Upper Midwest (Rust Belt) car, but it is nearly complete. If there is anything that you need please send me an email or private message and I'll get back to you. The engine does turn over, but there are teeth missing from the flywheel, probably the reason it was parked.
I can ship smaller parts without any issue and have had luck shipping larger items by Greyhound, FedEx and even the USPS before. I also have a 63 4 door Lark 6 cyl. parts car that is pretty well picked over and other Lark parts as well. As parts are sold I'll update the list below.
355323553335534
Parts Sold or Spoken For
Front bumper
Tailgate Stainless Trim
Heater Manifold
Heater Core Box
Heater Valve
Throttle Linkage
OD Cable
Front turn signals
Wiper Motor
Rear Side Windows
Thanks,
Nick
DMB-8
06-10-2014, 08:15 PM
How is the left side inner fender. I need one foe a champ pickup.The 59 and 60 are the same on the Lark.My name is Don Borger my cell # is 724- 651- 9320
61Lark
06-10-2014, 11:12 PM
Big old rust hole in the middle of the battery tray. Your best bet is Studebaker International.
61Lark
06-14-2014, 11:22 AM
I'll be pulling parts tomorrow so if there is anything that anyone is interested in or wants pictures of please let me know.
LeoH
06-17-2014, 02:55 PM
Nice Studemino donor mobile!
61Lark
06-19-2014, 11:46 PM
Someone was interested in doing just that, but unfortunately the body is probably too far gone.
61LaRk4dr
06-20-2014, 09:21 AM
Hello 61Lark,
PM sent.
61Lark
07-16-2014, 08:06 PM
Anyone need anything else?
brngarage
07-16-2014, 08:20 PM
Do you have the "heater manifold" that goes under the dash? This mounts up against the heater blower and distributes heat as well as providing connections for the defroster hoses. Thanks.
I just looked the part up in the manual. It is called the heater distribution duct and the part number is 1548278.
61Lark
07-16-2014, 11:35 PM
I sent you a PM.
RadioRoy
07-17-2014, 12:05 AM
How is the Fiberglas box that holds the heater core on the inner front right fender? The one on my 60 convertible is broken.
candbstudebakers
07-17-2014, 12:10 AM
Roy there might be a good one on the 61 in the shop now....Bob
Warren Webb
07-17-2014, 01:35 AM
61's are different unless it's a Champ.
61Lark
07-17-2014, 08:09 AM
Here are some additional pictures. I sent you a PM Roy.
363233632436325
tt600
07-19-2014, 07:38 PM
Looking for a 3speed overdrive to go behind a v8.
61Lark
07-19-2014, 09:30 PM
I've got a couple of T86s that would work. I sent you a private message.
doctorphil1
07-20-2014, 01:51 AM
Internally controlled antenna? Studebaker antenna kit AC-2688?
61Lark
07-20-2014, 10:27 PM
Yes I do. I sent you a private message.
http://i601.photobucket.com/albums/tt97/61Lark/60%20Lark%20VI%20Wagon/DSCN2282_zps350156b1.jpg (http://s601.photobucket.com/user/61Lark/media/60%20Lark%20VI%20Wagon/DSCN2282_zps350156b1.jpg.html)
Play Wagon
07-21-2014, 12:52 AM
Hello, 61 Lark,
I'm not looking to score for myself, as my project is a '59 two-door wagon, but I would guess that the quarter panel trim strips are scarce enough to save for someone. Anyway, best of luck...
JSC
Milaca
07-21-2014, 09:14 PM
Nick, I sent you a private message a month or so ago but it may not have gone through. I am wondering if you have a good starter that will fit a 1961 ohv 6 with a 3-speed tranny.
Thank you
61Lark
07-21-2014, 10:09 PM
Hello, 61 Lark,
JSC
That's a good point. I pulled the trim pretty early so it wouldn't be damaged working around the car.
Thank you
Sorry Brent I didn't get the PM. The starter on the car works, but the ring gear on the flywheel is damaged. I'd have to pull it first to make sure the bendix isn't damaged. I'd also have to look up to see if the 60 flathead six starter works on the 61 OHV six.
Nick
T.J. lavallee
07-22-2014, 03:52 PM
Nick, I need the plastic instrument cluster grill for my 1959 Lark as my desert car's plastic broke into a hundred pieces after removing the instruments to polish rust off the bezel. My phone number: (520) 665-0297. Thanks, Nick....T.J.
61Lark
07-22-2014, 10:48 PM
I'll check, but I can't promise you anything. The same thing happened to me so I pieced it back together and glued it.
doctorphil1
07-23-2014, 01:13 AM
Can't open the pm. I get a virus warning...
T.J. lavallee
07-23-2014, 05:33 PM
Thanks, Nick. I wish I could glue the pieces back together again but unfortunately some of it turned to dust! Well at least I know this has happened before. Here's hoping we get lucky. Thanks, again.....T.J.
61Lark
05-21-2015, 12:38 PM
Anyone need anything else before it gets scrapped?
sals54
05-21-2015, 02:00 PM
Looking for a couple things. PM sent
cultural infidel
06-30-2017, 02:53 PM
What are the chances that this old bucket of bolts is still alive and being parted?
61Lark
06-30-2017, 03:25 PM
Real good! What do you need?
swvalcon
06-30-2017, 05:44 PM
Nick how much of this car do you still have left?
61Lark
06-30-2017, 06:31 PM
The bulk of it is still there.
cultural infidel
06-30-2017, 10:20 PM
Interested in the rear window "wings" and the vent window add on accessories if still there
61Lark
07-01-2017, 09:20 AM
They should still be there, I sent you a private message.
HUDSONBROTHER1
07-01-2017, 03:30 PM
I sent you a PM. I need these sheet metal pasts 65256
61Lark
07-01-2017, 03:52 PM
I should still have those parts.
jackb
07-02-2017, 06:36 AM
someone wants the horn(s)... at least the hi tone...
61Lark
07-13-2017, 12:24 PM
I will be pulling parts tomorrow and Saturday. If anyone needs anything else, please let me know.
